Serge1971
Jul 19, 2024Aspirant
Problem with connecting new satellite RBS850
Hi, today I wanted to add 1 new (extra) satellite (RBS850) to my existing WiFi 6 mesh. It's a simple procedure so I started with the paring via the automised system - add a new satellite. All worked f...
- Jul 19, 2024
Did you update FW on the incoming new RBS to same version of FW thats on the current existing system?
Jul 19, 2024Guru - Experienced User
Serge1971
Jul 22, 2024Aspirant
Thank you soo much, that did the trick 🙏
- FURRYe38Jul 22, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
