Serge1971
Jul 19, 2024Aspirant
Problem with connecting new satellite RBS850
Hi, today I wanted to add 1 new (extra) satellite (RBS850) to my existing WiFi 6 mesh. It's a simple procedure so I started with the paring via the automised system - add a new satellite. All worked f...
- Jul 19, 2024
Did you update FW on the incoming new RBS to same version of FW thats on the current existing system?
Serge1971
Jul 22, 2024Aspirant
Thank you soo much, that did the trick 🙏
Jul 22, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
