eliday15's avatar
eliday15
Follower
Oct 28, 2020
Problem with massive devices
Hi I have a house with more than 80 devices connected to my network, with 1 orbi ax4200 routers 2 satellite ax 4200 and 1 rbk20.
The point is that my network always is falling because the massive devices in my network. I thought that if I buy more orbi this will solve the problem but don't.
Always after 3 or 4 hours it loses connection totally or I have wifi but I can't navigate.
The point is, how do I manage to connect massive devices without loosing the connection or killing the network
1 Reply
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    What devices do you have connected? Mfr and model#.
    What happens if you turn off half of your devices...then graduate adding some at a time?
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
    You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
