TerjeSly
Mar 13, 2022Aspirant
Problem with Netatmo Presence
I'm having problems with the Netatmo Presence camera. I have 2 cameras. One Satelite is approx. 1 meter from one camera and the other approx. 8 meters. Both cameras lose contact 3-6 times per. day a...
Mikey94025
Mar 13, 2022Hero
Try this to see if it improves your wireless compatibility for your cameras and other older 2.4Ghz devices:
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
See if that helps. If problems still persist, next try disabling AX mode for the 2.4Ghz band:
- Go to http://orbilogin.com/
- Click to the Advanced tab, Setup left menu, Wireless Setup
- Uncheck "Enable 2.4G" under the top Enable AX section
- Press Apply
- TerjeSlyMar 13, 2022Aspirant
Thank you so much. Will be testing next weekend.
- TerjeSlyApr 10, 2022Aspirant
I can not find that choice
- Mikey94025Apr 10, 2022Hero
TerjeSly wrote:I can not find that choice
Apologies, your RBR350 doesn't have AX mode so just try the CTS/RTS Threshold change.
