terra_orbi
Dec 11, 2022Aspirant
Problems with Connecting Satellite to Master
Hi, I have one RBR850 AX6000 and two RBS850 AX6000. Until some weeks ago one of the both Satellites was connected via Ethernet because the Satellite is at a space with very poor reception fr...
Dec 12, 2022Guru - Experienced User
Next time try a factory reset and setup from scratch after loading new FW. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
I just had my RBK853 system online for over 5+ days with no issues between the RBS and RBR:
RBS working fine over ethernet as well.
