asmitty512's avatar
asmitty512
Problems with Zoom and online gaming with AX6000
I'm using the AX6000 (RBK852 or RBR850) with Spectrum Internet 1Gbps service (940 Mbps) which has a lame 40Gbps up, but that may or may not matter. There is one satellite and one router.   WebEx se...
  • asmitty512's avatar
    asmitty512
    Dec 28, 2020
    FURRYe38 wrote:
    Firmware Version V3.2.16.22_1.4.9
    This is a harder question than I expected. It is listed on my portal as EN2251(Hitron) but doesn't look like the images. I'm not an expert on sleuthing this out. It looks more like
    E31N2V1
    What is the distance between the router and satellite(s)? Yes, there is 30 feet. Standard new construction of sheetrock.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    Any Wifi Neighbors near by? Yes. If so, how many? At least 3 broadcasting SSID. Not sure how I would know.
    Armor, and Set 20/40Mhz Coexistence to 40Mhz only. Try setting CTS to 2347. Save settings and reboot the router and satellite(s).
