asmitty512
Dec 28, 2020Aspirant
Problems with Zoom and online gaming with AX6000
I'm using the AX6000 (RBK852 or RBR850) with Spectrum Internet 1Gbps service (940 Mbps) which has a lame 40Gbps up, but that may or may not matter. There is one satellite and one router. WebEx se...
- Dec 28, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
Firmware Version V3.2.16.22_1.4.9
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?This is a harder question than I expected. It is listed on my portal as EN2251(Hitron) but doesn't look like the images. I'm not an expert on sleuthing this out. It looks more like
E31N2V1
What is the distance between the router and satellite(s)? Yes, there is 30 feet. Standard new construction of sheetrock.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteAny Wifi Neighbors near by? Yes. If so, how many? At least 3 broadcasting SSID. Not sure how I would know.
Armor, and Set 20/40Mhz Coexistence to 40Mhz only. Try setting CTS to 2347. Save settings and reboot the router and satellite(s).
Dec 28, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
asmitty512
E31N2V1
- FURRYe38Dec 28, 2020Guru - Experienced User
This one? https://www.hitrontech.com/product/en2251/
Or this one? https://www.hitrontech.com/product/e31n2v1/
Try installing a wifi scanning app on a pad if you have one.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
- asmitty512Dec 28, 2020Aspirant
Looks like this one
https://d15yx0mnc9teae.cloudfront.net/sites/default/files/SpectrumD31EMTA_New_Sheet.pdf
And to be clear, all my devices connect to wifi. It is only the Zoom and online gaming services that are problematic.
And thank you for spending your time providing assistance.
Ok, your ok on the modem. Just checking for built in router here. Which it doesn't have.
What are your speeds seen with a wired PC connected to the back of the RBR?
Some wifi devices will not see much over 400-500Mbps. Due to limiation of wifi antenna design. My iPhone 12 Max only sees around 400-500 average. Wired speeds thru the RBR should be near 900Mpbs...
