donawalt
Jul 16, 2023Hero - Experienced User
Procedure for Factory reset of RBS850
Hi all, I am just doing some maintenance on my RBR850/RBS850s (2) system, to factory reset them since it's been a long time. Yesterday I did a factory reset on the router and manually re-entered any ...
- Jul 16, 2023
Did you try the 2nd RBS with the 1st RBS turned OFF?
Try selecting Generate Backhaul Password on the RBRs web page Under Advanced Tab/Advanced Settings/Wireless Settings. Then press the sync button on the RBS then on the RBR or walk thru the Add Satellite feature on the RBRs web UI.
donawalt
Aug 03, 2023Hero - Experienced User
The only thing I would add in further testing, is if there are other RBSs online, power them OFF prior to the factory reset of each RBS. There should only be one RBS powered up, their current one being factory reset, at a time. I found problems with getting the factory reset (solid white) coming up with other RBSs online - an RBS would keep coming up BLUE (meaning connected and sync'd.)
- FURRYe38Aug 04, 2023Guru - Experienced User
Something I was told, use the ERASE button on the RBRs web page, also factory resets any connected RBS as well.
Something to keep in mind if you want to use this method to FR the entire system at once:
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
