donawalt
Jul 16, 2023Mentor - Experienced User
Procedure for Factory reset of RBS850
Hi all, I am just doing some maintenance on my RBR850/RBS850s (2) system, to factory reset them since it's been a long time. Yesterday I did a factory reset on the router and manually re-entered any ...
- Jul 16, 2023
Did you try the 2nd RBS with the 1st RBS turned OFF?
Try selecting Generate Backhaul Password on the RBRs web page Under Advanced Tab/Advanced Settings/Wireless Settings. Then press the sync button on the RBS then on the RBR or walk thru the Add Satellite feature on the RBRs web UI.
Jan 27, 2024Guru - Experienced User
Proceedure to Manually Firmware Update Orbi and Nighthawk Mesh systems.
