Chester0711
Sep 02, 2023Aspirant
Proper setup for RBR750 and 4 RBS750 satellites as Access Points
I have a 5000 sq/ft home and data drops in multiple rooms that I would like to leverage. I have an Orbi wifi6 system that I would like to use as access points. I have done the usual searching on YouT...
Sep 02, 2023Guru - Experienced User
For that size of home, the RBR and just two RBS should be enough.
You may have too many RBS deployed. https://youtu.be/UR0viMLISz4
I have a 5k Sq ft home, 3 story and only use two RBS.
I have done the usual searching on YouTube for instruction but I am not coming up with anything decent.
I set them all up myself based on some reading that I did and they work but the WiFi tends to drop often. It will go from a very solid connection to gone just like that while sitting still for a while. Then it comes back for a bit and we do the whole dance again a while later.
My fear is, I may have set them up incorrectly and it is causing issues. I have them setup as wired but I don’t think I set the AP mode up correctly. For instance, I am not utilizing AP mode in the software, mainly because I could never get a signal when in that mode.
Any help would be appreciated.
Oh, and I have the latest firmware setup too.
