moonwatcher64's avatar
Mar 21, 2023
Proper WPS Sequence for Orbi RBK853 - Struggling
Hi all, been a while.
Have am having issues trying to get our Miele wifi enabled kitchen goods connected to our Orbi RBK853.
It worked once (and worked solid) but in trying to make settings on the Miele device, I screwed it up and have not been able to get back to a connected device.
The first time I pressed the WPS button on the side of the RBK853 router and it worked perfect. But I cannot recall the sequence or how long to press for?
Also can you do WPS from one of the satellites? There is one closer  to the Miele device .... just 2 meters away which should be even more effective
Also should I press the WPS button on the Miele first or the Orbi?
Having had a bit of luck, I've lost my way on this one. I've reset the entire machine on the Miele side and their app and NW processes are clunky to say the least. But I just want to be sure I'm doing precisely the right thing on the Orbi side (which works great 99.9% of the time) so that I can drill down on the Miele side where I suspect the core of the issue is.
Any procedural details to make I'm doing things right would be appreciated.
Many thanks
  • CrimpOn's avatar
    CrimpOn
    It's on page 17 of the User Manual: https://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf
    • moonwatcher64's avatar
      moonwatcher64
      Luminary
      Thanks for sending the link. Appreciated.
      Unfortunately it's a little light on details that can help eliminate if I'm getting things wrong at the router side or the appliance side. For example, is it just a quick press of the sync button? Or do you need hold it in for a time? Other Netgear devices ask you to press for 2 seconds etc.
      Also it does not clarify if you can do this from the satellite device or if it must be the core router?
      It's also unclear if you press the button on the router first or the device you are trying to link, then the router.
      I have done it before and should remember but just trying to eliminate silly messed up steps or if I have a more challenging issue
      But thanks for the link all the same.
      • FURRYe38's avatar
        Try a quick press and if that doesn't work, try pressing the button for 2 seconds and see if that works.
