MikeCook66
Oct 19, 2023Aspirant
Proposed Network Design
I'm considering getting an Orbi, can anyone comment on whether this is an efficient network design ?
Oct 20, 2023Guru - Experienced User
Be sure if you ethernet connect the RBS, use the following methods to achieve that:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰️
Be sure you use a non managed ethernet switch.
if you don't use a multi gig switch, and only use a 1Gb LAN switch, be sure to connect the RBS using there 1Gb LAN ports. Don't connect the 2.5Gb ports.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
