CrazyEddie
Mar 30, 2023Apprentice
Protectli vault and Orbi 850 compatibility
I have an Orbi 850 base and two 850 satellites. I also have a Netgear cable modem (CM1150V). I am about to purchase a Protectli FW6Br2 vault firewall. Protectli said there will be no issues with the ...
CrimpOn
Mar 30, 2023Guru - Experienced User
CrazyEddie wrote:
Am I being too ambitious?
Considering that the RBR850 includes a firewall, it would be helpful to know the reason for investing (time and money) to put the entire system behind a firewall, which has the effect of making a number of applications more difficult.
- CrazyEddieMar 30, 2023Apprentice
I am trying to use the best firewall possible, and my understanding is that a hardware firewall would be better than the firewall in the Orbi router. I understand I will have to disable the Orbi firewall.
- FURRYe38Mar 30, 2023Guru - Experienced User
You can't disable Orbi Firewall. Only way would be to configure Orbi for AP mode.
- CrimpOnMar 30, 2023Guru - Experienced User
Well....... "maybe". A dedicated firewall will definitely have options* that the Orbi firewall does not. It certainly will be an adventure (learning Linux, whichever operating system you choose, how their DHCP server works, etc.)
The only way to disable the Orbi firewall is to place the router in Access Point mode, which also disables all sorts of features. (no Armor, no Parental Controls, no chance to define DNS servers, No DHCP reservations, no DDNS, no OpenVPN, no separation of primary vs. Guest WiFi devices. There's quite a list.
https://kb.netgear.com/000061277/Disabled-Features-on-the-Orbi-when-set-to-AP-Mode
*Orbi's firewall by default blocks every attempt to connect from the internet. 100%. The only options are
- to forward specific ports to specific devices on the LAN.
- to block specific devices on the LAN from specific internet access.
