CrazyEddie
Mar 30, 2023Apprentice
Protectli vault and Orbi 850 compatibility
I have an Orbi 850 base and two 850 satellites. I also have a Netgear cable modem (CM1150V). I am about to purchase a Protectli FW6Br2 vault firewall. Protectli said there will be no issues with the ...
CrazyEddie
I am trying to use the best firewall possible, and my understanding is that a hardware firewall would be better than the firewall in the Orbi router. I understand I will have to disable the Orbi firewall.
Mar 30, 2023Guru - Experienced User
You can't disable Orbi Firewall. Only way would be to configure Orbi for AP mode.
