Runex21
May 20, 2020Aspirant
PS4 constant reset orbi rbk752
Bought a new rbk 752 to upgrade from my ac3000 model. Speeds are great, love the armor upgrade, hate that its missing circle. However, I am experiencing an odd issue. My ps4 connection, which worke...
- May 20, 2020
Has a factory reset and setup from scratch been performed since last FW update.
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Set up a IP address reservation for the PS console on the RBR. Under Advanced Tab/LanSetup
Wired connection is preferred for gaming.
May 20, 2020Guru - Experienced User
