Runex21
May 20, 2020Aspirant
PS4 constant reset orbi rbk752
Bought a new rbk 752 to upgrade from my ac3000 model. Speeds are great, love the armor upgrade, hate that its missing circle. However, I am experiencing an odd issue. My ps4 connection, which worke...
- May 20, 2020
Has a factory reset and setup from scratch been performed since last FW update.
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Set up a IP address reservation for the PS console on the RBR. Under Advanced Tab/LanSetup
Wired connection is preferred for gaming.
Runex21
Thanks for the quick tips. Heres a followup.
1. I have not done a settings reset since the firmware update. I have reset the router a few times.
2. I looked at the rts/cts and they were set to 64. So I changed them to 2347.
3. I created an ip reservation.
It seems the big issue was the rts/cts as once i changed those, not only did my ps4 actually renew its network as it its supposed to, but the Dl speed increased by 300%.
Also, just a note, I agree wired is preferred, but i dont play much pvp, just need it for dl games and connecting to psn. My xbox is wired as i play pvp games on that.
Thanks for the help.
May 21, 2020Guru - Experienced User
Glad that worked.
Ya, I play PvP and like to have the best performance on xbox.
Enjoy. :smileywink:
