bsider
Sep 27, 2021Aspirant
PS4 Hardwire Stopped Connecting to store
I have a RBR750 ax4200. All was working well with the PS login and then it stopped. I connected direct to my modem and it work. When using the Orbi I can download games but can not connect to the st...
Sep 27, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
bsider wrote:
I have a RBR750 ax4200. All was working well with the PS login and then it stopped. I connected direct to my modem and it work. When using the Orbi I can download games but can not connect to the store. It shows timed out.
