alvarez95
Nov 24, 2020Aspirant
PS4 lagging when connected to RBS850 Tower
Hello, I am connected directly to the tower RBS850 ORBI Mesh network (V3.2.16.22_1.4.9) and I seem to be lagging when online gaming. My network plan is 300mbps download 55 upload. ISP COX ...
Nov 24, 2020Guru - Experienced User
Is the PS console wireless or wire connected? Wired is preferred for best gaming performance.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Set CTS to 2347. Save settings and reboot the router and satellite(s).
- alvarez95Nov 24, 2020AspirantI have them like 20 feet apart.
I am connecting the tower to the ps4 and using Wi-Fi, the performance is the same. It lags nonstop. :( I may have to go back to my linksys
I tried all those steps and it’s still performing the same- FURRYe38Nov 25, 2020Guru - Experienced User
20 feet is too close to each other. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. Do you still get the lag if you wire connect the PS console?
WIred gaming is preferred.
