Juanhump
Oct 19, 2023Follower
Purple light over night
I have RBR 750 which was working fine. Went to bed and got up to a purple light. I have tried to reboot and reinstall bit nothing helps. Anybody know what's going on?
1 Reply
PINK is an indicator of the RBR not getting any good data signal from the ISP modem or ONT.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Something to check with the modem/ONT and your ISP services.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.What Firmware version is currently loaded?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
