Dustin_T
Dec 07, 2022Aspirant
Put main and guest wireless on same subnet?
The RB850 seems to default to 192.168.1.1 for the main wireless and 192.168.2.1 for the guest wireless... I want to use the guest wireless to connect non WIFI6 compatible devices to my network while...
Dec 07, 2022Guru - Experienced User
No possible since the GN is tied to the WAN side of the router and is supposed to be isolated from the LAN side of the router. This is expected design.
