Wizzard370
Dec 05, 2022Tutor
Puzzling MTU settings
Have Orbi RBK353 set up. In Orbi set up, set MTU via WAN setup to 1492 and applied. All seems to be fine. However if I check in CMD prompt : netsh interface ipv4 show subinterfaces I get MTU...
- Dec 05, 2022
No. MTU values are not needing any adjustments on the LAN side.
Dec 05, 2022Guru - Experienced User
MTU on Orbi is for the WAN side only. Check with your ISP to see what MTU value is needed if it's required by the ISP.
- Wizzard370Dec 05, 2022Tutor
Thank you. So, is there a way to set the WiFi MTU in Orbi (via Command prompt say)?
- FURRYe38Dec 05, 2022Guru - Experienced User
- CrimpOnDec 05, 2022Guru - Experienced User
See page 39 of the user manual: https://www.downloads.netgear.com/files/GDC/RBK352/RBK352_RBK353_UM_EN.pdf
No command prompt needed.
