Wizzard370
Dec 05, 2022Tutor
Puzzling MTU settings
Have Orbi RBK353 set up. In Orbi set up, set MTU via WAN setup to 1492 and applied. All seems to be fine. However if I check in CMD prompt : netsh interface ipv4 show subinterfaces I get MTU...
- Dec 05, 2022
No. MTU values are not needing any adjustments on the LAN side.
Wizzard370
Dec 05, 2022Tutor
Thank you. So, is there a way to set the WiFi MTU in Orbi (via Command prompt say)?
Dec 05, 2022Guru - Experienced User
