weirdbeardmt's avatar
Jun 15, 2024
Question about Guest and IoT network
Orbi 6 / RBR750 / 7.*.21 FW.   I do not have the IoT or Guest network enabled in the Admin panel but they're still visible using a Wifi scanner like Netspot. It seems like they appear when the RBR ...
  • CrimpOn's avatar
    Jun 15, 2024
    Not my experience. No.
    Suggest trying a WiFi scanner that detects and displays hidden WiFi SSIDs, such as WiFi Info View (free for Windows from Nirsoft https://www.nirsoft.net/utils/wifi_information_view.html )
    This phenomenon of Orbi routers displaying Guest and IoT SSIDs temporarily during the start up process has been reported on the forum before.
