donawalt
Jan 26, 2024Mentor - Experienced User
Question for your WIFi channel/band experts
So if you check out the image, I am apparently the first in the area (I live in a rowhouse) with WiFi 6 GHz band! My RBR960 router is set to use channel 69. Is there a reason to change it higher and ...
Jan 27, 2024Guru - Experienced User
I tend to use the lower 5Ghz channels for better compatibility for older 5Ghz devices and they may not support the DFS channels. I use 40 here.
- donawaltJan 27, 2024Mentor - Experienced User
HI Furry, my question was on any advantage of moving the 6GHz channel, not 5GHz! But on the 5GHz, in my area everyone and their brother are at channel 40, I am on 48 - I tried both and there was a nice performance bump at 48 (~10% or so)
- FURRYe38Jan 27, 2024Guru - Experienced User
Use what you feel works for you on 6Ghz. I use channel 69 as well. Though I don't have any mobile devices that support 6Ghz as of yet. A RAXE500 and two PCs with AX210 and BE200 PCI cards in them that support 6Ghz is all I have to work with in my sad inventory. 😋
Yeah that's what I'll do unless some compelling reason said to do otherwise. I find the 6E on mobile is very spotty, could that be different on a different channel given no one else is on any of the channels? Or is it likely that's just the nature of the 6E with a small range and needing to jump back to 5GHz more often...
