donawalt's avatar
donawalt
Hero - Experienced User
Oct 10, 2022
Question on firmware update of RBR850 and RBS850
Hi all,   I have a RBR850 and 2 RBS850s from a second house that we no longer have. I factory reset them at the time I took them out of service, resetting them through the little button on the devi...
  • plemans's avatar
    Oct 10, 2022
    You can download the firmware and manually update it.
    Or you could just connect it to your regular network in a double nat and update it and set it up for them. Once you have the ssid/ setup/firmware updated, simple power it off and disconnect it.
    I've done that before.
