tucsontico's avatar
tucsontico
Virtuoso
Jun 30, 2021
Questions About Migrating from RBK53 to RBK753
I was an "early adopter" of the ORBI system in 2016 with an RBK53. It has served me very well but I want to move my RBK53 to my vacation home and migrate to the AX4200 RBK753. (Costco has them on sale for $400. Router + 2 Sats.) I've done a bunch of reading in this forum but want to know if there are any "best practices" I should be aware of before initializing my new ORBI RBK753?
Appreciate any words of wisdom before setting off on a new router adventure.
  • FURRYe38's avatar
    I would udpate the system prior to going on line with it. Manually update the RBS first then RBR.
    There is a new beta available if you want to request it. Some users saw DNS issues on theres. Some did not. If you see DNS issues, please ask Christian_R for access to it.
    30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
    I would not enable Armor or Access Controls until you are confident the system is running well first.
    • tucsontico's avatar
      tucsontico
      Virtuoso
      Thanks for the input. As others have noted in this forum, a good way to easily migrate is to use the same SSID and password. I plan on configuring my RBK753 exactly like my RBK53 with Sats in the same locations. They are over 30 feet away from the router and each other. I currently have Armor and access controls disabled. I also have IP reservations for all my 30+ devices.
      I do have to dasiy chain the Sats to get WiFi out to my attached garage (unable to easily hard wire for backhaul due to concrete block walls) but have had no issues with that in over 3 years of operation.
      I will follow your suggestion and update the firmware on the RBK753 and check for DNS issues before putting it online. Will report back after the swap out and a few days of up time.
      • FURRYe38's avatar
        Definately use same SSID name and PW. You can even set up the Orbi AX system and when you ready to go online and replace the 50 series, just leave the 50 series RBR ON, disconnnect any LAN connections from the 50 series and connect them to the Orbi AX RBR and connect the ISP cable to the RBR as well. Power cycle the ISP Modem/ONT the power ON the RBR750. After you see the front LED slowly pulsate White or even go dark, then turn OFF the RBR50 and your wireless device should auto connect and migrate to the Orbi AX system.
        You may see some items that won't connect. If you do, try setting CTS values to 2347 as 64 is default on Orbi AX systems which differs from Orbi AC systems.
