nk1975
Jun 15, 2020Aspirant
Questions about wired backhaul
Hello I recently bought the Orbi AX6000 rbk852 2 pack and am pretty happy with it. However I still get a few weak signals around my house. I have the router upstairs and the satilite in the b...
- Jun 15, 2020
Yes.
Jun 15, 2020Guru - Experienced User
Sometimes wired vs wirelss is more stable than wireless or if you want a RBS out a fare distance from the RBR, the RBS won't connect wirelessly so wired RBS can be setup for this configuration. The only draw back is that the back haul speed is limited to 1000Mbos vs 2400Mbps that the Orbi AX provides wirelessly. 1000Mpbs wired speeds are still good and have good performances.
nk1975
Ok, thanks!
So I can still have my satelite in the basement wired into the gaming system,
and buy the 3rd satalite and do the wired backhaul into the main router?
That's what I want to do.
I am fine with the speeds, as the wireless speeds on 5g and kinda all over the place.
Thanks!
