donawalt
Aug 26, 2023Hero - Experienced User
Questions on 1 DoS attack log entry
I just saw one DoS entry in my log this morning: [DoS attack: DoSPortScan] from source 192.168.1.153,port 59847 Thursday, Aug 24,2023 16:49:38 My question is, it says the source is an interna...
- Aug 26, 2023
Sometimes those are false positives.
MIght scan your mac for any malware.
Do you use your mac with IoT devices?
Try disabling Limit IP address Tracking on the mac under networking for the connection.
donawalt
HI FURRYe38 , no IoT, Malware scans are clean and have been. Probably a false positive, if it persists I'll try turning off the 'limit ip address tracking', as this is the first time I've seen it!
Aug 26, 2023Guru - Experienced User
Remember, Orbi, anything can happen. đ
