donawalt's avatar
donawalt
Mentor - Experienced User
Aug 12, 2020
Questions on configuring RBR850 Orbi router
Hi all, I was wondering if you could comment on a few questions I have on the set up of a relatively new Orbi RBR850 router with satellite. Everything is running well, and the speeds are great! I have 1 GB Comcast internet.
1. A simple thing, but every time I log into orbilogin.net to look at something, it makes me add my password again - even if I have checked the checkbox to save the password many times. Is this a bug or do I have something set up wrong?
2. I originally set up LAG successfully (CM1200 modem), but then I turned it off as I saw some posts saying there were "issues with the CM1200 and LAG". Is this old news and no longer an issue, or something I should avoid for now?
3. Should I manually install the hot fix 3.2.15.32? The app updated me to 3.2.15.25. I didn't see much on what the hot fix was for.
Thanks for answering my questions!
