dkelling
Aug 08, 2022Aspirant
Randomly drops internet connection
I am having the same problem with latest update and email logging. A constant problem and does not seem to be getting better
dkelling
RBR 850 with 2 RBS's
4.6.8.5_2.1.9
ARRIS Surboard S33, Cox Gigabit
Yes
7-10 times a day
Cat6
2 RBS's deployed
3400 sq ft
RBR to Downstairs RBS 50+ ft
5GHZ is 40, 2.4 is 7
I have scan wireless signals around my house about 5 or so. These channels were picked with least overlap of interference with other signals
20-30 devices connected
Been having thise problem for over 2 yrs now. Very frustrating ,
here is latest email log
Aug 08, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Being that your ISP modem has a 2.5Gb port, CAT6A STP cable would be recommended here between the modem and RBR. I did see some problems with my 8 series connected to my CAX80 on it's 2.5Gb port with CAT6 UTP cables. Changed to CAT6A STP cable and that problem resolved.
For that size of home you may have one too many RBS deployed and too much Wifi signals in the home:
I would try turning OFF one RBS and test this configuration out.
Set 2.4Ghz to 1 6 or 11. Channel 7 is not a primary channel that should be used.
Can also try enabled SIP/ALG under Advanced tab/Setup/WAN Setup.
FYI, Please edit out any MAC addresses prior to posting captures in a public forum for security reasons.
- dkellingAug 08, 2022Aspirant
Yes and have followed those steps
No factory reset and new setup not done since last update
I will check with Cat6A STP cable
I will try tuirning off RBS upstairs and see what happens
I will change channel for 2.4
- FURRYe38Aug 08, 2022Guru - Experienced User
I would also recommend you monitor the System Uptime seen on the routers IP address/debug.htm page.
It has reset 3 times in last 3 hrs. System Uptime made it to just shy of 3 hrs and then reset. I unplugged one of my RBS's too earlier.
- FURRYe38Aug 09, 2022Guru - Experienced User
No factory reset and new setup not done since last update< I would give this a try at some point as well.
- TC_in_MontanaAug 09, 2022Virtuoso
I have sent you two DMs (look for the envelope at the top of the page - and click on it) to get those DMs.
If you feel comfortable providing the information asked for in the DM, it will help us better analyze your issues.
Thanks!
