pss16
Jul 31, 2020Aspirant
Range extender for Orbi ax6000
Are there specific range extenders available for the Orbi Ax6000. Will any model of the AC range extenders work? Kindly reply. Many thanks in advance.
- Aug 03, 2020
I'm currently using an EAX80 extender connected wirelessly to the Orbi AX6000 to get higher LAN speeds, but have turned off the wireless broadcast of the EAX80.
The EAX80 connects at WIFI 6 speeds and setup was straight forward. Have had no stability issues since setting up the EAX80.
farmrt88
Aug 03, 2020Star
Aug 03, 2020Guru - Experienced User
I tested my two EXs 7500 anfd 7700 and they connect so they seem to work.
