Adriankn
Oct 29, 2024Aspirant
RB350 no internet
We’ve had the Orbi set up for 1 year and now it’s stopped working and TPG (Aus) advised the router is no longer recognized. Have added Pppoe and set up VLAN 2 priority 0 and still no internet and Net...
- Oct 30, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
CrimpOn
Oct 29, 2024Guru - Experienced User
"stopped working" is a bit ambiguous.
- The Power LED (on the back) glows green, correct?
- Does the system broadcast a WiFi signal?
- The comment about PPPoE and VLAN: was that done a year ago when the system was first installed, or just recently?
- Netgear hardware warranty in the US is one year. I have no idea what it is in Australia.
Adriankn
All good. Problem solved. TPG was able to help do a re set up
- FURRYe38Oct 30, 2024Guru - Experienced User
Enjoy. 📡
