kk223
Jul 19, 2023Follower
rb752 crash every time when use pc battlenet client downloading
have to hard reboot the rb750 to work again,i had try to use older firmware or the newest firmware still have issue, when the battlenet client downloading ,the router will crash
Jul 19, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is Armor Or Taffic Meter enabled on the RBR thru the Orbi app?
