mgfeal
Sep 09, 2021Aspirant
RBK 353 - Constant Disconnections - Firmware 4.4.0.10
Hi, I own a Netgear Orbi RBK353. Both satellites connected using Ethernet. First weeks all worked with a few problems, but since I updated to firmware 4.4.0.10 (4.4.0.10_2.10.63 for the principa...
Sep 09, 2021Guru - Experienced User
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
mgfeal wrote:
Hi,
First weeks all worked with a few problems, but since I updated to firmware 4.4.0.10 (4.4.0.10_2.10.63 for the principal router) is unusable.
Devices disconnected every day. Devices that are one meter away. To solve it I need to reboot Orbi satellites.
Anyone with the same problems?
Thanks!
- Obtc101Sep 13, 2021Aspirant
Hello mgfeal did you find a solution to this and did the reset work?
I've been suffering the same issue since the firmware landed, having previously had a solid connection throughout.
When I review the router's logs on the web interface, it seems that my connection drop outs coincide with potential DoS attacks and scans. I am aware of other users reporting lots of false positives for the DoS attacks, so they may not be genuine. However in any case, the drop outs seems to correlate with them at the same time.
My ISP modem and connection during this period is fine, so it's definitely the Orbi network
Any advice appreciated
Thanks
- FURRYe38Sep 13, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a factory reset and setup from scratch been performed since last FW update?
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Thanks
