mgfeal
Sep 09, 2021Aspirant
RBK 353 - Constant Disconnections - Firmware 4.4.0.10
Hi, I own a Netgear Orbi RBK353. Both satellites connected using Ethernet. First weeks all worked with a few problems, but since I updated to firmware 4.4.0.10 (4.4.0.10_2.10.63 for the principa...
mgfeal
Sep 13, 2021Aspirant
I'm browsing to one of the satelites using its IP. And I discovered that 2.4GHz is not working. So devices are disconnected.
But I don't why. Orbi router has enable 2.4 and 5G.
Any idea?
Thanks!
Sep 13, 2021Guru - Experienced User
Then check boxes next to 2.4 and 5G are for enabled AX mode on the RBR. Not enabled of the 2.4G or 5G radios in general.
Has a factory reset of the RBR and RBS and setup from scratch been performed then check the RBS status page for 2.4Ghz?
Any idea?
Thanks!
