Lancastrian
Oct 07, 2022Aspirant
RBK 752 - Reconfigure for new ISP
In about a month's time I'll be changing ISP and getting a full-fibre 900/900 service. For now I have a 75/20 ADSL service through a regular phone line. The ISP supplied a combined modem/wireless ro...
- Oct 08, 2022You don’t need to do a factory reset. You just need to change Orbi from AP mode to Router mode AFTER you plug it in the new ONT.
Lancastrian
I'm aware of the double NAT issue - that's why I have disabled wireless on the ISP modem/router and set the Orbi Router to Access Point mode. This way the ISP modem/router will handle NAT, and I can make use of the Orbi's superior wi-fi. This is already what you suggested in your point 3. I'm happy enough with this setup for the short time it will be necessary.
When I transfer to the new ISP, my existing combined modem/router will be returned to the old ISP (it won't work with a full fibre connection anyway), so I will have just the Orbi which I will then revert back to router mode and connect direct to the new fibre ONT.
The gist of my original question was: what's the best way to change the current Orbi settings to the new ones required by my new ISP? Need I do a full factory reset, or just specify the log in requirements of my new ISP? I ask because I'm not sure whether any other fields will have been changed by my first switching to AP mode, then back again to router mode.
Oct 07, 2022Guru - Experienced User
I would try changing the mode on the RBR from AP to Router. And while the RBR is rebooting and making the change, connect the RBR to the new ISP modem or ONT. See what happens. It should get connected ok.
- ekhalilOct 08, 2022MasterYou don’t need to do a factory reset. You just need to change Orbi from AP mode to Router mode AFTER you plug it in the new ONT.
- LancastrianOct 08, 2022Aspirant
ekhalil & FURRYe38 - thanks to you both for your suggestions.
I now have a good idea of what to try when my new fibre connection is installed.
- ekhalilOct 08, 2022MasterGreat, all the best!
