Lancastrian
Sep 30, 2022Aspirant
RBK 752 - VLAN requirements from ISP
Apologies if someone else has posted this question previously, and apologies for my dreadful lack of knowledge. Although I'm computer literate, the details of networking are a bit of a mystery to me!...
- Sep 30, 2022
Thanks for the info.
The ISP normally supplies a router, but it is apparently not so good. They do allow use of customer's own router but will not provide support for it. I'm sure they will supply all the necessary VLAN settings when asked.
My real question was whether or not the RBK752 supports ISP-side VLANs and it appears the answer is yes!
Thanks once again
Sep 30, 2022Guru - Experienced User
IF your ISP has that requirement then they will have all the details on how to set it up.
I presume it maybe similar to this:
https://kb.netgear.com/25724/VLAN-tagging-setup-for-Nighthawk-router
Thought you may be located else where.
Contact the ISP and have them help you with this.
- LancastrianSep 30, 2022Aspirant
Thanks once again
- FURRYe38Sep 30, 2022Guru - Experienced User
đ
