RJG202
Nov 10, 2023Guide
RBK 752 Guest Network question and general information
My 5 1/2 year old R7800 and Ex8000 combo having router issue lately (disconnecting connections and forcing password change when logging into it)and I picked up a rbk752 last night. I read manuals onli...
- Nov 16, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
RJG202
Nov 15, 2023Guide
All good now. I hit the upgrade in the ui and did not look at the version even though it was made clear in the posts. No issues, downloaded both zips, backed up and upgraded as per notes with satellite first. Thanks
Nov 16, 2023Guru - Experienced User
Enjoy. 📡
