IcedCorn's avatar
Jun 11, 2020
RBK 753 - LED won't go away
Just upgraded to the RBK 753 (AX4200 w2 satellites).   Weird thing though. ...the LED doesn't go away. It's always on. I know many wanted that but I don't. Any thoughts on how to get rid of it (out...
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last update? Something to try on the RBR if you haven't.
    IcedCorn wrote:
    The RBR 750 (Router) has a solid white light on it, . Satellites are fine (no lights).
    Orbi mobile app shows everything as fine, I can use wifi and wired fine.
    Logging into 192.168.1.1 from a web browser is fine, I get the orbi setup page. The LED doesn't change.
    The firmware displayed in the upper right corner of the web browser is:
    V3.2.15.25_1.3.15
