IcedCorn
Jun 11, 2020Tutor
RBK 753 - LED won't go away
Just upgraded to the RBK 753 (AX4200 w2 satellites). Weird thing though. ...the LED doesn't go away. It's always on. I know many wanted that but I don't. Any thoughts on how to get rid of it (out...
- Jun 12, 2020
Has a factory reset and setup from scratch been performed since last update? Something to try on the RBR if you haven't.
IcedCorn wrote:The RBR 750 (Router) has a solid white light on it, . Satellites are fine (no lights).
Orbi mobile app shows everything as fine, I can use wifi and wired fine.
Logging into 192.168.1.1 from a web browser is fine, I get the orbi setup page. The LED doesn't change.
The firmware displayed in the upper right corner of the web browser is:
V3.2.15.25_1.3.15
IcedCorn
Jun 12, 2020Tutor
V3.2.15.25_1.3.15
Jun 12, 2020Guru - Experienced User
V3.2.15.25_1.3.15
- IcedCornJun 14, 2020Tutor
Apparently that was all that needed to be done after the firmware upgrade. Factory reset and re-setup and everything is good. Thanks!
- FURRYe38Jun 14, 2020Guru - Experienced User
Good to hear. Glad that worked. Be sure to save off a backup configuration to file for safe keeping. Saves time if a reset is needed next time.
Enjoy. :smileywink:
