Dec 30, 2021Guru - Experienced User
RBK 8 Series Only - Unofficial v4.6.6.11 Firmware Experiences
So since NG is giving out some unofficial FW to those who have called in to NG support and users have posted links to this version of FW, I figured I'd try it myself.
https://community.netgear.com...
Jan 04, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Dd852 wrote:
Just to add: this firmware seems to have solved the minor problem that was driving me crazy, of one of my satellites repeatedly going through the white/blue flashing sequence every 30 minutes or so. Since updating... the satellite has been quiet, well-behaved, unlighted as it should be.
NGSvensk
Jan 04, 2022Apprentice
Update on this firmware. It works! No disconnects. Satelite works well... mesh seems to work at picking up moving clients. 3 days and counting
