dglsmcd_USMC
Aug 15, 2020Luminary
RBK 852 New Firmware Version: V3.2.16.6_1.4.4
Christian_R FURRYe38 RBK 852 Firmware Version: V3.2.16.6_1.4.4 Currently only available through web GUI and/or Orbi app-NG download website does not show this update No release notes avai...
Aug 15, 2020Guru - Experienced User
Thanks for letting us know.
Mine doesn't seem to be on the update approval list, yet:
| Router | RBR850 | RBR850 | V3.2.15.32 | No New Firmware Available |
| Satellite | RBS850 | Orbi Satellite-BM | V3.2.15.32 | No New Firmware Available |
| Satellite | RBS850 | Orbi Satellite-DR | V3.2.15.32 | No New Firmware Available |
I'll have to wait. Hoping this new version has the NAT Filter fix. :smileywink:
dglsmcd_USMC
Hmmm-strange-try reinitiating the check after the initial check and see what happens.
Model Name Device Name Current Firmware Version Status
- FURRYe38Aug 15, 2020Guru - Experienced User
Thats a negative ghost rider. Tried 3 times. Opera and Edge browsers. :smileyembarrassed:
- Chuck_MAug 15, 2020Mentor
[Enhancements] Supports enabling or disabling the wireless 11AX mode on 2G or 5G separately.
[Enhancements] Includes some security enhancements.
[Enhancements] Supports the IGMP over the PPPoE WAN connection.
[Enhancements] Supports the profile configuration to set up the ISP's VLAN/IPTV settings during installation. The following are the limited ISPs that are supported currently: France Orange;Singapore SingTel;Malaysia Unifi, Maxis.
[Bug Fixes] Fixes some GUI related issues.- Chuck_MAug 15, 2020Mentor
Note for those with RBS-50s attached via ethernet!
If you have any hardwired RBS-50's attached to your RBR 850, you must power them off before any firmware update attempts will be successful.
Once firmware update is complete and rebooted; Repower yoiur RBS50s.
