dglsmcd_USMC
Aug 15, 2020Luminary
RBK 852 New Firmware Version: V3.2.16.6_1.4.4
Christian_R FURRYe38 RBK 852 Firmware Version: V3.2.16.6_1.4.4 Currently only available through web GUI and/or Orbi app-NG download website does not show this update No release notes avai...
Aug 18, 2020Guru - Experienced User
NG has finally posted the downloadable FW files:
New Features and Enhancements:
- Supports enabling or disabling the wireless 11AX mode on 2G or 5G separately
- Includes some security enhancements
- Supports the IGMP over the PPPoE WAN connection
- Supports the profile configuration to set up the ISP’s VLAN/IPTV settings during installation. The following are the limited ISPs that are supported currently:
- France Orange
- Singapore SingTel
- Malaysia Unifi, Maxis
Bug Fixes:
- Fixes some GUI related issues.
Security Fixes:
- Fixes security issues.
Get the files here:
https://kb.netgear.com/000062217/RBR850-RBS850-Firmware-Version-3-2-16-6
This version also has the NAT Filter fix for those playing xbox with two or more game consoles:
FYI, I updated mine today. Did a dirty update instead of factory reset and setup from scratch. I just went online with it in router mode. RBR came up quickly and all my devices connected with out any problems thus far. RBS is wired and showing wired connection
I can confirm NAT Filter is fixed now for those gamers with two or more game consoles:
http://nattest.net.in.tum.de/individualResult.php?hash=ec5468cc1d93ce3e13c7b460fe7859e6
Speeds are good too:
I'll check for any DNS issues. DNS is automatic for me.
Orbi app is connecting and working.
- MindblowerzAug 19, 2020Aspirant
FURRYe38 I think my setup is kinda close to yours. You mentioned in some other posts that your setup is relatively stable now on the older fw. What do u have for the usual settings?
- Enable 20/40mhz coexistence
- Enable WMM for both 2.4/5G
- preamble 2.4/5G
- CTS/RTS 2.4/5G
- Enable AX 2.4/5G
- DNS Auto/manual
Think I'll be fine if I mimic your settings lol
- FURRYe38Aug 19, 2020Guru - Experienced User
Mindblowerz wrote:FURRYe38 I think my setup is kinda close to yours. You mentioned in some other posts that your setup is relatively stable now on the older fw. What do u have for the usual settings?
My settings were stable on the last version of v32 as well.
- Enable 20/40mhz coexistence YES
- Enable WMM for both 2.4/5G YES
- preamble 2.4/5G AUTOMATIC
- CTS/RTS 2.4/5G 64
- Enable AX 2.4/5G YES
- DNS Auto/manual AUTO - Not Seeing any DNS issues thus far since going online with v6 last nite.
Not bad speeds for a wireless mac book pro 2018 on AC:
