dglsmcd_USMC
Aug 15, 2020Luminary
RBK 852 New Firmware Version: V3.2.16.6_1.4.4
Christian_R FURRYe38 RBK 852 Firmware Version: V3.2.16.6_1.4.4 Currently only available through web GUI and/or Orbi app-NG download website does not show this update No release notes avai...
Aug 24, 2020Guru - Experienced User
I just confirmed that my two EX extenders connect to Orbi AX 8 series so these could be used in a pinch with Orbi AX systems.
Nov 07, 2020Guru - Experienced User
Connected a ASUS AX router in wireless bridge mode to my Orbi AX 8 series. Speed test is with Windows 10 wired PC connected behind ASUS wireless bridge.
- dglsmcd_USMCNov 07, 2020Luminary
- FURRYe38Nov 07, 2020Guru - Experienced UserWhat for?
- dglsmcd_USMCNov 09, 2020Luminary
According to the release notes for the GT-AX11000 9566 firmware version stability/security is improved but if all is well-you are right-why bother?
- FURRYe38Nov 09, 2020Guru - Experienced User
I also tend to look over user experiences as well:
https://rog.asus.com/forum/forumdisplay.php?301-ROG-Routers
dglsmcd_USMC wrote:According to the release notes for the GT-AX11000 9566 firmware version stability/security is improved but if all is well-you are right-why bother?
