Bpasker
Mar 07, 2021Tutor
RBK 852 Satellite Security Type: None
I have found that my wifi satellite is not secure on the satellite only on 5 ghz. I have tried to reset but when I do it creates a new wifi SID for my 2.4 on my satellite. You can see my mac connecti...
- Mar 09, 2021
Ok, thanks for the update. Yes, the RBS and RBR can't be parallel connected to the host router, the RBS needs to be in series behind the RBR to propberly get synced and work correctly with the RBR. 3rd party routers may or may not work correctly to let data pass thru from the RBR to the RBS when in parallel so maybe upon initial installation it worked however upoin a FW update on the host router or on Orbi has changed that configuration which wasn't supported in the first place. RBS need to be connected to the RBR as such when ethernet connected:
This cofiguration has worked fine over the couple of years I've had my systems online.
Bpasker
Mar 07, 2021Tutor
Mar 07, 2021Guru - Experienced User
Pictures will need to be approved by a forum moderator. You can use the Choose FIle button to attatch the picture files to the post and we can download them for review quicker.
Please give feedback to the questions presented.
- BpaskerMar 07, 2021Tutor
RBR850 wireless page and firmware.
RBS firmware and status
- FURRYe38Mar 07, 2021Guru - Experienced User
And is the same FW version thats on the RBS?
Set WPA2 and AES only...
Ok, so try a resync of the RBS and RBR while you have the RBS near or in the same room as the RBR.
Set WPA2 and AES only on the RBR prior to the resync.
