kinetica
Dec 07, 2022Aspirant
RBK 852 White Blinking Light
First, I'm an IT pro, 20+ yrs experience. I have tried ALL available troubleshooting steps, including powercycling the router & satellite, and factory resetting the unit with the pinhole until the l...
kinetica
Appreciate the response. Tried both solutions. TFTP wasn't able to establish a connection.
NMRP said "No response after 60 seconds. Bailing out".
Leads me to believe the switch component isn't functioning at all...might explain the flashing white light if it didn't recognize the link from the modem.
Dec 08, 2022Guru - Experienced User
If its under a year old, you can start the rma process. It should still be within warranty.
and I know its a stupid question but I've seen people try the tftp/nmrpflash using the wan port. It needs to be a lan port.
