Ely
Jun 26, 2021Luminary
RBK-852 with Comcast 1200GB Internet
Hello everyone, I just purchased an RBK-852 (AX600) and I'm having so many issues setting it up. I have my Orbi connected to an ARRIS - SURFboard S33 Modem this modem has one 2.5GB ethernet ...
CrimpOn
Jun 26, 2021Guru - Experienced User
Ely wrote:So I had to connect the Orbi to the 2.5GB Ethernet and them my PC normally to one of the Orbi ports. that also works, but then I do't get anything above 940Mbps in the speed tests.
This is correct. The modem and Orbi both have 2.5G ethernet ports, which means the modem can deliver 2.5G to the Orbi. Because the Orbi has only gigabit LAN ports, the maximum speed that can be achieved on any device connected to the Orbi is 1GM. (In practical terms, it is impossible to achieve 1GB. 940MB sounds about right. So what happens to the other 400mb? It is available to other devices connected to the Orbi, either via ethernet or WiFi.
Ely wrote:HWill the Orbi be able to get a connection If I purchase a 10GB Switch and then connect that swith to the modem's 2.5GB port then connect the Orbi and PC to its ethernet ports?
Never. The modem can connect to only one device. It can associate the public IP address with only one ethernet MAC address. The WAN (yellow) Orbi port must be connected directly to the modem.
Perhaps there is a WiFi router out there somewhere that has both 2.5GB WAN port and 2.5G LAN port, but it is certainly not the Orbi.
Ely
CrimpOn wrote:Never. The modem can connect to only one device. It can associate the public IP address with only one ethernet MAC address. The WAN (yellow) Orbi port must be connected directly to the modem.
Thanks a lot for your help, I understand what you explained and it makes perfect sense. However this modem has two ethernet ports (which means it can provide two diferent IPs) According to the manufacturer's help page here, they say the following:
>>>>It is possible to connect two devices to the S33. However, the cable provider must provide an Internet IP Address to each device for Internet access. If both devices cannot connect to the Internet, contact the cable provider to request an additional Internet IP address.
I tried calling Comcast to see if they can provide me with a second IP address and after almost 2 hours nobody seems to know what I'm talking about and then the call got dropped. Really frustrating. :-( I puchased this modem and router because Comcast sent me an e-mail saying I should get a new modem in order to get the new fast speeds of above 1Gb that they are now offering to customers to subscribe to internet package I have.
If anybody else has any other ideas, I would appreciate the help.
