bojackkk
Mar 15, 2020Aspirant
RBK 852(wifi6 ) wifi download speed only 100Mbps under Gigabit internet
Seems Netgrar community doesn't even have this modle when create the discusstion..... Buy from Amazon https://www.amazon.com/gp/product/B07WNY2WKG/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1 W...
Apr 04, 2020Guru - Experienced User
Go take this one back and get another.
reneky
Apr 05, 2020Tutor
I tried it at a neighbours place, and was able to connect at 1Gbs, so the port works, but there is an incompatibility between the RBK852 and the Mikrotik RB2011iL-IN when negotiating the link speed.
Thanks for the responses!
- FURRYe38Apr 05, 2020Guru - Experienced User
Great test with the nieghbor. Glad the RBR is really working. Might get with Mikrotik and see if there is any settings or configuration or maybe a FW update that can help.
Good Luck.
reneky wrote:I tried it at a neighbours place, and was able to connect at 1Gbs, so the port works, but there is an incompatibility between the RBK852 and the Mikrotik RB2011iL-IN when negotiating the link speed.
