bojackkk
Mar 15, 2020Aspirant
RBK 852(wifi6 ) wifi download speed only 100Mbps under Gigabit internet
Seems Netgrar community doesn't even have this modle when create the discusstion..... Buy from Amazon https://www.amazon.com/gp/product/B07WNY2WKG/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1 W...
Mar 20, 2020Guru - Experienced User
Load up WiFi Sweet Spots on your iPhone then turn OFF The RBS. Connect the iPhone to the RBR and see what speeds the iPhone is connected at with the RBR. iPhone should be around 3 to 6 feet from the RBR.
bojackkk
Apr 05, 2020Aspirant
Not much different. I test several times over several hours.
iPhone 11 Pro Max Wifi connected to the router, no Satellite on.
Download at most can be 200Mbps, just two times. And all other is still fall in 100Mbps.
- Upload speed is still almost 300-600 Mbps in above situation.
Even 200Mbps compare to 1000Mbps is 80% loss, that's terrible, I'm thinking about 400-600Mbps
