Kensington6503
Jul 03, 2021Aspirant
RBK 853 - Cannot tell if satellites are working
This is a post about the RBK853|Orbi Tri-band Mesh WiFi6 System AX6000 (not apparently a selection option yet). I don't think it really matters, though, for my question/problem. I set up the RBR ...
- Jul 04, 2021
FURRYe38 You were absolutely right. I identified the runs to my satellites, connected them directly to the RBR, and they appear on the dashboard. Still can't use the app yet, but that is fine for now. Thanks!
Jul 03, 2021Guru - Experienced User
Your switch may have a user UI feature, if so, try to disable IGMP and or Green Ethernet protocols on this switch.
If you need a switch in between the RBR and RBS, then you can install another switch in between the RBR and RBS.
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Kensington6503
Jul 04, 2021Aspirant
- FURRYe38Jul 05, 2021Guru - Experienced User
:smileywink:
